Multiple asr900?
Jitex
Hi ppl, i hope someone can answer this. I wonder if it would be able to have two asr900 chassis acting as a single logical router or in some way working as one?
smilstea
If you are asking about the asr9000 series routers then yes, there is a feature called 'nv edge' or 'nv cluster' that supports two routers acting as one logical router. The last supported release for this feature is 5.3.4 though.
For the asr90x series routers I am not sure, as this forum is for XR and they do not run XR.
Sam
smilstea
Sam
