NCS-5501-SE USB
V_V
Hi all,
Is there a way of copying *.rpm files from USB to harddisk: on a NCS-5501-SE ?
V_V
Anyone ?
pganesha
Try the procedure below
RP/0/RP0/CPU0:NCS-5501-SE#
RP/0/RP0/CPU0:NCS-5501-SE#show filesystem
Thu Sep 27 00:19:12.510 UTC
File Systems:
Size(b) Free(b) Type Flags Prefixes
3962216448 3851993088 flash-disk rw apphost:
5971681280 4506451968 harddisk rw harddisk:
2069835776 2048102400 flash-disk rw disk0:
0 0 network rw ftp:
31458738176 29750853632 flash-disk rw disk2: <<<<<<<<<<<<<<<<<<<<<<<
0 0 network rw tftp:
480907264 479059968 flash rw /misc/config
RP/0/RP0/CPU0:NCS-5501-SE#dir disk0:
Thu Sep 27 00:19:17.611 UTC
RP/0/RP0/CPU0:NCS-5501-SE#show log last 10
RP/0/RP0/CPU0:Sep 27 00:17:46.329 : usb_disk[67393]: %OS-SYSLOG-6-LOG_INFO : mounted device to /disk2: <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
RP/0/RP0/CPU0:NCS-5501-SE#dir disk2:
Thu Sep 27 00:21:11.084 UTC
Directory of disk2:
41 -rwxr-xr-x 1 1092833280 Feb 14 2017 ncs5500-mini-x.iso-6.1.3 <<<<<<<<<<<<<<<<<<<<<<<<<<<
30721424 kbytes total (29053568 kbytes free)
RP/0/RP0/CPU0:NCS-5501-SE#copy disk2:ncs5500-mini-x.iso-6.1.3 harddisk:ncs5500-mini-x.iso-6.1.3
Thu Sep 27 00:21:34.094 UTC
Destination filename [/harddisk:/ncs5500-mini-x.iso-6.1.3]?
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
Thanks for your response pganesha - its all sorted!
