onep - XRv vs. physical hardware
Todd Graham
Level 4
Level 4
Is anyone using the onep service under XRv?  Posted a similar question on the ViRL community forum, but appears as more of a XRv as opposed to a front-end problem.   If I try enabling onep under XRv 5.3.0 the config commit fails and starts generating non stop dumper /process alarms.  Can post output, but it's identical when I try under ViRL, or just a standalone XRv instance under ESXi directly.   I don't get any errors if I try it on physical hardware, but did not find any documentation indicating it is not a supported feature (such as layer2) on virtual.
If anyone wants to test:
config
onep
commit
See what results you get.
0 Replies 0
