OSPF load-sharing is not working
hsien-ping tang
Dear Experts,
I have a question about load-sharing in OSPF 。
There are two equal-cost routes in the routing tale, in my idea, the forwarding behavior should be load-sharing. however, the traffic is forwarding on one uplink.
Below is "show" info:
RP/0/RSP0/CPU0#sh run router ospf 2600
Thu May 17 15:54:13.318 GMT
router ospf 2600
nsr
log adjacency changes
router-id 10.130.127.3
nsf ietf
redistribute connected route-policy CONN
area 0.0.137.11
interface Bundle-Ether2601
network point-to-point
fast-reroute per-link
interface Bundle-Ether2602
RP/0/RSP0/CPU0:#sh route 10.156.24.128
Thu May 17 15:54:22.287 GMT
Routing entry for 10.156.24.128/32
Known via "ospf 2600", distance 110, metric 3
Tag 3489678349, type extern 1
Installed May 17 11:02:27.300 for 04:51:55
Routing Descriptor Blocks
10.158.26.33, from 10.156.1.11, via Bundle-Ether2601
Route metric is 3
10.158.26.37, from 10.156.1.12, via Bundle-Ether2602
Route metric is 3
No advertising protos.
RP/0/RSP0/CPU0:#show cef 10.156.24.128
Thu May 17 15:54:34.956 GMT
10.156.24.128/32, version 302721, internal 0x1000001 0x0 (ptr 0x726f412c) [1], 0x0 (0x71ce5a78), 0x0 (0x0)
Updated May 17 11:02:27.301
Prefix Len 32, traffic index 0, precedence n/a, priority 1
via 10.158.26.33/32, Bundle-Ether2601, 4 dependencies, weight 0, class 0 [flags 0x0]
path-idx 0 NHID 0x0 [0x716a4654 0x0]
next hop 10.158.26.33/32
local adjacency
via 10.158.26.37/32, Bundle-Ether2602, 3 dependencies, weight 0, class 0, platform-non_preferred [flags 0x0]
path-idx 1 NHID 0x0 [0x716a55c0 0x0]
next hop 10.158.26.37/32
local adjacency
RP/0/RSP0/CPU0:#show cef 10.156.24.128 hardware egress
Thu May 17 15:54:42.204 GMT
Updated May 17 11:02:27.302
local adjacency
local adjacency
RP/0/RSP0/CPU0:#show cef 10.156.24.128 detail
Thu May 17 15:54:50.822 GMT
gateway array (0x71aeeb58) reference count 120, flags 0x0, source rib (7), 0 backups
[121 type 3 flags 0x8401 (0x71bb48d0) ext 0x0 (0x0)]
LW-LDI[type=3, refc=1, ptr=0x71ce5a78, sh-ldi=0x71bb48d0]
gateway array update type-time 1 Dec 29 01:00:57.071
LDI Update time Dec 29 01:00:57.071
LW-LDI-TS May 17 11:02:27.302
local adjacency
local adjacency
Load distribution: 0 (refcount 121)
Hash OK Interface Address
0 Y Bundle-Ether2601 10.158.26.33
I would like to ask experts that
1. what does "platform-non_preferred" mean in show cef?
2. and how come it will be appeared?
3. Is this symptom caused by configuring IP FRR?
Thank you,
Tom
In cluster we always prefer interfaces on the local rack. That's what platform-non_preferred is used for. Are members of Bundle-Ether2601 and Bundle-Ether2602 distributed across both racks?
9 Replies 9
xr-escalation
Try configuring 'maximum-paths' under OSPF. That should enable ECMP.
/Aleksandar
Hi Aleksander
Isnt it enabled by default?
actually, yes. :) Are you taking these commands from a cluster by any chance? Which platform is this?
I am using ASR9010(nVEdge Cluster) with IOSXR 5.3.3.
Because this Router has service traffic on it, I don,t have the authorization to change config. except show command.
thank you
Thanks for the reply,
member info of Bundle-Ethernet 2601 & 2602 shown as below,
RP/0/RSP0/CPU0:#show bundle bundle-ether 2601
Fri May 18 10:18:30.357 GMT
Bundle-Ether2601
Status: Up
Local links <active/standby/configured>: 1 / 0 / 1
Local bandwidth <effective/available>: 1000000 (1000000) kbps
MAC address (source): a80c.0d32.631b (Configured)
Inter-chassis link: No
Minimum active links / bandwidth: 1 / 1 kbps
Maximum active links: 64
Wait while timer: 2000 ms
Load balancing: Default
LACP: Operational
Flap suppression timer: Off
Cisco extensions: Disabled
Non-revertive: Disabled
mLACP: Not configured
IPv4 BFD: Not configured
Port Device State Port ID B/W, kbps
Gi0/7/1/17 Local Active 0x8000, 0x0019 1000000
Link is Active
RP/0/RSP0/CPU0:#show bundle bundle-ether 2602
Fri May 18 10:18:36.034 GMT
Bundle-Ether2602
Status: Up
LACP: Operational
Gi1/7/1/17 Local Active 0x8000, 0x0023 1000000
Link is Active
If it prefers interfaces on the local rack in cluster, in our design, it should even be load-sharing, isn't it?
No, that's the point of preferring local interfaces. We don't want to load-balance if that includes sending packets over IRL.
Is there any way to load-balance including the IRL?
Do you mean load-share when traffic has to traverse the IRLs from one rack to the other in cluster?
This is handled automatically, and all IRLs are treated like they are in 1 bundle, so we use bundle hashing to achieve load balancing. You cannot put the IRLs in a bundle themselves though.
Sam
