Parallel BGP sessions with the same peer
jalalyounus
Hi Everyone;
I hope everybody is keeping well.
I have a situation here.
I have a client hwo is unning a bgp session with us using a 1G ethenet connection (asr9000).
The same client now wishes to have another bgp session with us on a 10G interface (asr 9000).
I had assigned them a temporary IP prefix from a /29 range. The original bgp peering (on 1 g connection) uses a /30 range.
Current configs on my side are as follows:
neighbor 86.107.28.242 (10 G)
  remote-as xxxx
  use neighbor-group abc
  description xxx
  address-family ipv4 unicast
  route-policy bbb in
  route-policy ccc out
neighbor 86.107.23.210 (1G)
  remote-as xxxx
  description xxx
  route-policy bbb in
There is no intention to implement bgp laod balancing feature (using mltipath or otherwise). Do you think this config would work fine?
regards
10 Replies 10
Alexei Kiritchenko
Yes, that would work. You’ll get 2 sessions with absolutely identical parameters for all routes except the peer’s IP address.  Hence, the best path would be the path with the lowest peer address, routes from 86.107.23.210 would be taken as the best in this case.
BGP Best Path Selection Algorithm
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml
/A
Thanks Alexei.
So I do  not need to set multipath value to 2? if not, please advise how the peering would get established?
regards
Hi Jalal,
Your config from the first post would work just fine. Source and destination IP addresses are different, so there are no any issues making both sessions UP even if physically that is the same router.
/A
Thanks alot Alexei again.
Just one thing, i wanted check with you. I read somewhere that 2 bgp neighbors connected through physical interfaces(not loop backs), can only have one active bgp peerig session between them. If two same cost links are used to i interconnect them only one would work.
Since in my scenario, there two pysical connections between the two neighbors and these connections are not equal cost links. One is 1G and the other is a 10G. I wonder what might happen here, which link would be chosen by bgp to select the routes to be installed in the routing tbale of the client?
regards
BGP would choose a path based on BGP Best Path Selection Algorithm
in this scenario, the best path would be the path with the lowest peer address, hence routes learned from 86.107.23.210 would be taken as the best (compare to routes from 86.107.28.242 ) in this case and installed into the routing table.
Regard,
/A
Thanks again boss.
Would they still be able to see the routes coming in through the 10 G link though?
regards
What you get is something like this. BGP will learn same network over 2 sessions. Here the net 3.3.3.0/24 was learnt from 100.100.46.6 and 100.100.64.6 (that is the same router here)
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network           Next Hop           Metric LocPrf Weight Path
*> 3.3.3.0/24         100.100.46.6             0             0 10 ?
*                     100.100.64.6             0             0 10 ?
100.100.46.6   is taken as the best (marked with > ) as the IP address is lower compare to 100.100.64.6
RP/0/0/CPU0:R4#sh bgp 3.3.3.0/24 bestpath-compare
Tue Mar 27 10:46:12.441 EEST
BGP routing table entry for 3.3.3.0/24
Versions:
Process           bRIB/RIB SendTblVer
Speaker                16         16
Last Modified: Mar 26 17:52:21.000 for 16:53:52
Paths: (2 available, best #1)
Advertised to update-groups (with more than one peer):
   0.2
Path #1: Received by speaker 0
   0.2
   100.100.46.6 from 100.100.46.6 (192.168.0.6)
     Origin incomplete, metric 0, localpref 100, valid, external, best, group-best
     Received Path ID 0, Local Path ID 1, version 16
     best of AS 10, Overall best
Path #2: Received by speaker 0
Not advertised to any peer
   100.100.64.6 from 100.100.64.6 (192.168.0.6)
     Received Path ID 0, Local Path ID 0, version 0
     Higher neighbor address than best path (path #1)
The routing table has only  the best path installed
RP/0/0/CPU0:R4#show route 3.3.3.0/24
Tue Mar 27 10:46:47.425 EEST
Routing entry for 3.3.3.0/24
Known via "bgp 65000", distance 20, metric 0
Tag 10, type external
Installed Mar 26 17:52:20.911 for 16:54:26
Routing Descriptor Blocks
   100.100.46.6, from 100.100.46.6
     Route metric is 0
No advertising protos.
If the 1G link fail, the routing table would install routes pointing to 100.100.64.6.
But you can modify the behavior and distribute the routes among the links as you wish or put a ebgp multipath to load balance between them.
for example here is the routing table when ebgp multipath is enabled:
Tue Mar 27 11:05:08.512 EEST
  Installed Mar 27 10:59:56.936 for 00:05:12
    100.100.46.6, from 100.100.46.6, BGP multi path
      Route metric is 0
    100.100.64.6, from 100.100.64.6, BGP multi path
      Route metric is 0
/A
just One query,
in this Case, BGP Prefer routes from the peer with the lowest peer IP address.
here the selection will work ( between 2 IPv4 peer IP's)
in case, I have one BGP neighbor is IPv4 and One more neighbor ship with IPv6.
and getting the same prefix x.x.x.x/24 via both the neighbors ,  How selection will work !!!
BR//
Dipankar.
I guess what you mean is that you carry one address family - e.g. IPv4 using IPv4 and IPv6 transport. Situation is that IPv4 NLRI supports only IPv4 NH and IPv6 NRLI supports only IPv6 nexthops. Thus using this approach you will still need to use route-map to modify transport NH to the one understood by your address-family. Meaning for IPv4 AF you will keep IPv4 transport NH but modify IPv6 transport to IPv4.
In this case you will again end up comparing IPv4 against IPv4 and IPv6 against IPv6 as in your first example.
Niko
HTH,
Niko
hi,
using IPv4 and IPv6 transport.- Correct
only IPv6 nexthops. - correct
transport NH to the one understood by your address-family. correct
Now my actual Query.
R1(2069::1/64)------(2069::2/64) R2
R1 loopback 1.1.1.1 and 2021::1/128
R2 loopback 2.2.2.2 and 2022::1/128
I have 1 BGP sessions on IPv4 TCP ( from 1.1.1.1 to 2.2.2.2) and AF is IPv6.
I have 1 more BGP session on Ipv6 TCP ( from 2021::1 to 2021::2) and AF is
IPv6.
Now here for a certain Route 2000::/64 is coming from R1 to R2, i will get
2 Peer address
- NH is 2069::1 and Peer is 1.1.1.1 ( changed the NH using map)
- NH is 2021::1 and peer is 2021::1
So how the selection will happen on the basis of Peer address ( i mean how
i will compare a ipv4(1.1.1.1) and IPv6 address(2021::1))
