Perl script for ASR9K with satellite
mcagiola
Hi all, i need a little help on a perl script used on ASR9K:
my $n_args = $#ARGV + 1;
if ($n_args != 1) {
    print "Usage: showmac <bridge-group>\n";
    exit;
my $bgroup=$ARGV[0];
my $cli_output = `nvgen -c -q gl/l2vpn/dbase/vpls_bridge/$bgroup/`;
(my $bdomain) = $cli_output =~ m/\s+bridge-domain\s(.*)/;
my $cli_output = `l2vpn_show -g $bgroup 0x9`;
(my $mod) = $cli_output =~ m/\s+\w+\d\/(\d)\/\d\/\d.*/;
# Magic happens here
if ($mod == 0) { $mod = 2049; }
if ($mod == 1) { $mod = 2065; }
if ($mod == 2) { $mod = 2081; }
if ($mod == 3) { $mod = 2097; }
if ($mod == 4) { $mod = 2145; }
if ($mod == 5) { $mod = 2161; }
if ($mod == 6) { $mod = 2177; }
if ($mod == 7) { $mod = 2193; }
my $cli_output = `l2fib_show_client -l $mod -BrigeDomain $bgroup:$bdomain -macAddress`;
my @values = split("\n", $cli_output);
foreach my $line (@values) {
  if ( !($line =~ m/MAC/ || $line =~ m/l2vpn/ || $line =~ m/.*BD.*/) ) {
    print $line."\n";
This script release the output like this:
RP/0/RSP0/CPU0:XXXX001#run perl /harddisk:/scripts/showbmac.pl XXX_XXXX
Wed May 31 09:42:56.141 CET
Mac Address    Type    Learned from/Filtered on    LC learned Resync Age         Mapped to
ac60.b675.6fe3 dynamic Gi0/0/1/0.3915              0/0/CPU0   0d 0h 0m 2s        N/A
044e.06c9.f092 dynamic Gi0/0/1/1.3915              0/0/CPU0   0d 0h 0m 17s       N/A
044e.06ce.f8a0 dynamic Gi0/0/1/1.3915              0/0/CPU0   0d 0h 0m 15s       N/A
044e.06ce.fa8a dynamic Gi0/0/1/1.3915              0/0/CPU0   0d 0h 0m 19s       N/A
[SNIP]
9038.090a.131f dynamic Te0/2/0/0.3915              0/2/CPU0   0d 0h 0m 14s       N/A
9038.0946.58d5 dynamic Te0/2/0/0.3915              0/2/CPU0   0d 0h 0m 13s       N/A
9038.0973.67ce dynamic Te0/2/0/0.3915              0/2/CPU0   0d 0h 0m 11s       N/A
Now the problem is that: if I use the same script in a device with satellite installed on it, I have NO results:
RP/0/RSP0/CPU0:xxxxx002#run perl /harddisk:/scripts/showbmac.pl xxx_xxxxx
Wed May 31 09:48:09.747 CET
even if I should have the same results on that device.
The only difference on those devices is that one of those have a satellite installed on it… I need to modify the script to show the results also if the device have satellite installed on it.
The satellite interface are named:
Gi100/0/0/<ID>
Can anyone help me?
Thanks In advance.
Marco
Aleksandar Vidakovic
hi Marco,
neat approach to changing the look and feel. Have you tried printing the output at various steps (especially before and after the magic with the 'mod')? That should give some hints.
/Aleksandar
