Policy Based Routing Issue for ASR 903 Router
csawest.dc
Level 3
Level 3
Hi All, We have done PBR configuration on our ASR 903 Router , each and every configuration the device has taken , then also the policy based routing is not taking place , kindly give your inputs for resolving the issue , below is the configuration :-
The current template is "video" template.
"bootflash:asr903rsp1-universalk9_npe.03.16.09.S.155-3.S9-ext.bi"
ip access-list extended SET-DS-1
permit tcp any eq www xxx.xxx.xxx.0 0.0.0.255
permit tcp any gt 1024 xxx.xxx.xxx.0 0.0.0.255
permit udp any gt 3000 xxx.xxx.xxx.0 0.0.0.255
ip access-list extended SET-DS-2
ip access-list extended SET-US-1
permit tcp xxx.xxx.xxx.0 0.0.0.255 any eq www
permit tcp xxx.xxx.xxx.0 0.0.0.255 gt 1024 any gt 1024
permit udp xxx.xxx.xxx.0 0.0.0.255 gt 3000 any gt 3000
ip access-list extended SET-US-2
permit tcp xxx.xxx.xxx 0.0.0.255 gt 1024 any gt 1024
route-map RTM-1-DS permit 10
match ip address SET-DS-1
set ip next-hop verify-availability 10.139.101.2 4 track 1
set ip next-hop 10.139.101.2
route-map RTM-1-DS permit 20
match ip address SET-DS-2
set ip next-hop verify-availability 10.139.103.2 4 track 1
set ip next-hop 10.139.103.2
route-map RTM-1-US permit 10
match ip address SET-US-1
set ip next-hop verify-availability 10.139.101.2 1 track 1
route-map RTM-1-US permit 20
match ip address SET-US-2
set ip next-hop verify-availability 10.139.103.2 1 track 1
interface GigabitEthernet0/3/7
description *** Connected to LAN1 ***
ip address xxx.xxx.xxx.xxx 255.255.255.252
ip policy route-map RTM-1-US
load-interval 30
negotiation auto
interface BDI19
description *** ABC-LAN ***
ip address xx.xxx.xxx.xxx 255.255.255.252
interface GigabitEthernet0/3/0
description *** WAN ***
ip address yyy.yyy.yyy.yyy 255.255.255.252
ip flow ingress
ip policy route-map RTM-1-DS
load-interval 30
negotiation auto
0 Replies 0
