Procedure for replacing a ASR9006 chassis in an existing NV edge cluster
Sebastiaan1978
I have a running cluster with 2 ASR9006 chassis. I want to replace 1 chassis by a new ASR9006 chassis.
The current config (IOS XR 4.3.4) looks like this:
nv
 edge
  control
   serial 123 rack 0
   serial 456 rack 1
The final config without downtime for rack 0 should be :
nv
 edge
  control
   serial 123 rack 0
   serial 789 rack 1
My best guess is:
1) power down chassis in rack 1
2) nv edge control serial 789 rack 1 command on chassis in rack 0
3) connect all control and data links to new chassis in rack 1
4)  power up new chassis in rack 1 (with identical config as rack 0, including the "nv edge control serial 123 rack 0"  "nv edge control serial 789 rack 1" commands )
Can anyone tell me if this is the correct procedure? Is this possible without downtime? Does anybody have experience with this? Does anybody know if there is a Cisco documented procedure? The only document I can find is the single chassis to cluster migration document.
Many thanks in advance!
Sebastiaan
Aleksandar Vidakovic
Hi Sebastian,
Presuming you already have the new rack1 running the exact same SW package as rack0, below is the procedure you can follow.
[*] get rack1 chassis serial number
show inventory chassis
[*] reload rack1 into ROMMON mode
[*] clear boot variables
unset CLUSTER_RACK_ID
unset CLUSTER_NO_BOOT
unset BOOT
sync
[*] power down rack1 and connect cluster cables
[*] on rack0 configure cluster to accept new serial number
admin config
nv edge control serial <RACK0CHASSISSERIALNUMBER> rack 1
[*] power on rack1
[*] use "show nv edge control control-link-protocols" on rack0 to watch for cluster join
[*] verify health
show redundancy
show platform
[*] test a failover
redundancy switchover
[*] verify health
show redundancy
show platform
Aleksandar
Thanks a lot Aleksandar,
That was what I was looking for. Do you have any real life experience with this procedure, just to make sure because it is a "live" environment so any downtime of Rack 0 would impact our customers.
Sebastiaan
yes, this was performed by multiple customers. Just make sure that both racks have the exact same pies (main package and SMU/SP) installed before you start.
Aleksandar
Great, thanks again!
Sebastiaan
