QOS Policy in Cisco ASR9k
Inthiyaz
policy-map SUBS_IN
 class class-default
  set dscp default
  police rate 150 mbps
   exceed-action transmit
   violate-action drop
 end-policy-map
policy-map SUBS_OUT
 class class-default
  set dscp default
   violate-action drop
policy-map 2gig
class class-default
police rate 2 gbps
conform-action transmit
exceed-action drop
I have a question with regarding the above config.
exceed-action transmit --> it's often used to mark over rate packets. It can also be used to accumulate stats on over rate packets?
violate-action drop --> Configures the action to take on packets that violate the rate limit?
when should I use conform-action/exceed-action drop vs violate-action drop?
Perfect! Thanks for your time!
smilstea
Let's look at 4 examples:
Marking based on Policing state
ASR9K supports setting a field based on the policer result. Consider the following policy-map,
Policy-map parent
    Class class-default
              Police rate 10 Mbps peak-rate 20 mbps
                      conform-action set dscp af12
                      conform-action set cos 2
                      exceed-action set dscp af13
                      exceed-action set cos 3
If the traffic rate is 0-10 Mbps the conform-action of setting dscp to af12 & cos 2 is executed. If the traffic rate is 10-20 Mbps, then the exceed-action of setting dscp to af13 and cos 3 is executed.
Marking and hierarchical policy-map
This section explains when using marking and policing based marking on a hierarchical policy-map what the expected behavior is. Note in ASR9K, in a 3 level explicit MQC policy hierarchy set/mark action is supported on only the bottom two levels in hierarchy. MQC describing ordering of feature-execution and indicates the following
  1. Set/Mark actions independent of policer would be executed first from TOP of the hierarchy to bottom.
  2. Set/Mark actions based on policer would be executed next from bottom of the hierarchy to the top.
Policy-map parent
    Class class-default
              Set cos 1
              Set dscp AF11
              Police rate 10 Mbps peak-rate 20 Mbps
                      violate-action drop
              service-policy child
policy-map child
    Class c1
              Set cos 4
              Set qos-group 1
              Police rate 5 Mbps peak-rate 10 Mbps
                      conform-action set qos-group 2
                      conform-action set cos 5
                      exceed-action set qos-group 3
                      exceed-action set cos 6
                      violate-action drop
    class class-default
For e.g. in the above policy-map hierarchy let’s consider the traffic is in conform state on both parent and child policer, then the order of execution is as follows
  1. set cos 1 (parent policy)
  2. set dscp AF11 (parent policy)
  3. set cos 4 (child policy – overrides step 1)
  4. set qos-group 1 (child policy)
  5. set qos-group 2 (child policy, policer conform state, overrides step 4)
  6. set cos 5 (child policy, policer conform state overrides step 3)
  7. set dscp af12 (parent policy, policer conform state, overrides step 2)
  8. set cos 2 (parent policy, policer conform state overrides step 6)
End result for such a flow is to set
  • cos 2
  • dscp af12
  • qos-group 2
Similarly for other traffic effective mark actions can be derived as shown below.
Packet belonging to
Child policer state
Parent policer state
Marking actions performed
Child-C1
Conform
conform
Cos 2
Dscp af12
Qos-group 2
Child-C1
Conform
Exceed
Cos 3
Qos-group 2
Dscp af13
Child-C1
Conform
Violate
Drop
Child-class-default
X
Conform
Set cos 2
Set dscp AF12
Child-class-default
X
exceed
Set cos 3
Set dscp AF13
Child-class-default
X
violate
Drop
Child-c1
Exceed
Conform
Set cos 2
Set dscp AF12            Set qos-group 3
Child-c1
Exceed
Exceed
Set cos 3             Set dscp AF13
Set qos-group 3
Child-c1
Exceed
violate
Drop
Child-c1
Violate
Don’t Care
Drop
Single Rate policer (1R2C)
ASR9K would instantiate a single Rate 2 color policer when user configures just one rate associated to a policer in the policy-map. For e.g.
Policy-map policer
     Class class-default
          Police rate 10 Mbps
             Conform-action transmit
             Exceed-action drop
For the above policy-map if the traffic is <=10 Mbps, the policer would take any action configured under “conform-action” sub-mode. In this case if traffic is <=10, it would be transmitted, if > 10 Mbps it would be dropped.
Note an optional burst size can be configured for the rate, to limit the length of burst in addition to the rate. If this optional burst size is not specified, then a 100ms burst size of the rate specified is used internally.
Policy-map policer
     Class class-default
          Police rate 10 Mbps burst 100 kbytes
             Exceed-action drop
Dual Rate policer (2R3C)
When a peak-rate needs to be enforced separately from a committed rate, a 2R3C policer can be utilized. In ASR9K when user specifies two rates (rate & peak-rate) a 2R3C policer would be instantiated. For e.g.
Policy-map policer
     Class class-default
             Exceed-action set cos 0
             Violate-action drop
In the above policy-map, if traffic is <=10 Mbps it is transmitted. If 10Mbps< traffic <= 20 Mbps then the cos is remarked as 0 and packets are transmitted. If the traffic is > peak-rate then it is dropped.
Note once again optional burst size can be configured for the rate as well as peak-rate, to limit the length of burst in addition to the rate. If this optional burst size is not specified, then a 200ms burst size of the rate specified is used internally.
Policy-map 2R3C_policer
     Class class-default
          Police rate 10 Mbps burst 10 kbytes peak-rate 20 Mbps peak-burst 20 Kbytes
             Violate-action drop
Let me know if you have any further questions.
Sam
Sam
Thanks for the detailed explanation.
I assume
policy-map SUBS_OUT
 class class-default
  set dscp default
   exceed-action drop
   If the exceed-action set to drop, then I do not have to add "violate-action drop". I believe it's by default violation drop.
The wording in the configuration guide for the two is confusing, but based on the examples I have seen your example above would work. But even without it by default the exceed action is to drop the packet when a policer has no burst settings configured.
Sam
