Qos
razu
!!% 'qos-ea' detected the 'warning' condition 'QOS policy is not supported on this interface type
how solved this for NCS 5011
8 Replies 8
mivens
You will have a better chance of someone taking their time to help you if you provide some basic information such as what the policy is that you are trying to apply and on what interface type (bundle, physical interface, sub-interface, BVI etc), what software version is running.
tkarnani
we will need more information, interface type, egress/ingress? what type of policy?
please review the restrictions listed in the config guide
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5500/qos/66x/b-qos-cg-ncs5500-66x/b-qos-cg-ncs5500-66x_chapter_010.html
Physical Interface and Bundle Interface policy shape working fine. But polcy shape and policy map don’t work sub interface under bundle or Physical interface.
Please share sub interface policy shaping configurations.
Here we share whats error are showing after apply sub interface policy.
!!% 'qos-ea' detected the 'warning' condition 'QOS policy is not supported on this interface type.
policy-map Client1
class class-default
shape average 400000 kbps
end-policy-map
interface Bundle-Ether110.98
Service-policy output client1
Thanks in Advance
tkarnani
this is ncs5011, shaping on subinterfaces are not supported, please see restrictions
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5000/qos/60x/b-ncs5000-qos-configuration-guide-60x.pdf
All QoS features currently supported on physical interfaces, are also supported on all link bundle
interfaces. Applying QoS on sub-interfaces is not supported
Dear Concern,
We have NCS5002 also. What about this? is policy work in sub interface or not?
Yes, all NCS5k platforms have this limitation. ncs5001 5002 5011
thanks
lokmanhossain
Good day,
How about ncs540!!
Thanks.
