%ROUTING-BGP-3-BUF_TOO_SHORT
Rojer-bkk
Hi Expert,
Anyone  has ever seen the error message about %ROUTING-BGP-3-BUF_TOO_SHORT  please help to share idea to solving. I found this error on CRS-1
Rojer,
you are hitting CSCth56941:
bgp_show traceback on exec "sh bgp vrf def nei < > dampened-routes"
Symptom:
bgp_show traceback
Conditions:
This is seen when the "sh bgp vrf default neighbors 202.48.1.1 dampened-routes" command is executed when there are dampened routes for the particular neighbor
Workaround:
none
this should be fixed in 4.2
Hope that helps,
Ivan.
6 Replies 6
Laurent Aubert
This message has no impact and is harmless. It usually appears after entering a show bgp command.
Laurent.
Hi Laurent,
Thanks for feedback.
How can i clear this message?
Ivan Krimmel
Level 7
Level 7
Hi Rojer,
could you please let us know IOX version this CRS-1 is running on and the exact steps you've done for this message to pop up. If you found it in a syslog chain, then a snippet of a few consecutinve messages around it would be helpful.
Ivan.
Hi Ivan,
This error %ROUTING-BGP-3-BUF_TOO_SHORT is generated after we use command
#show bgp neighbor x.x.x.x dampened-routes
When x.x.x.x is the neighbor that have been damped.
IOS-XR 4.0.1
Rojer,
Symptom:
bgp_show traceback
Conditions:
Workaround:
none
Hope that helps,
Ivan.
Hi Ivan,
Thank you very much
