Routing Policy Options for RIP
I was reading the documentation in ASR9010, and we can redistribute bgp into rip, with a route-policy applied where we match communities, right?
http://www.cisco.com/en/US/docs/routers/asr9000/software/routing/configuration/guide/rcasr9krip.html#wp1009407
Route policies comprise series of statements and expressions that are bracketed with the route-policy and end-policy keywords. Rather than a collection of individual commands (one for each line), the statements within a route policy have context relative to each other. Thus, instead of each line being an individual command, each policy or set is an independent configuration object that can be used, entered, and manipulated as a unit.
Each line of a policy configuration is a logical subunit. At least one new line must follow the then, else, and end-policy keywords. A new line must also follow the closing parenthesis of a parameter list and the name string in a reference to an AS path set, community set, extended community set, or prefix set. At least one new line must precede the definition of a route policy, AS path set, community set, extended community set, or prefix set. One or more new lines can follow an action statement. One or more new lines can follow a comma separator in a named AS path set, community set, extended community set, or prefix set. A new line must appear at the end of a logical unit of policy expression and may not appear anywhere else.
However when I try to apply the route-policy, returns an error.
See the following configuration:
RP/0/RSP0/CPU0:EC-XPTO1#sh run route-policy XXX-bgp-to-rip
Thu Mar 15 14:08:42.861 WET
  if destination in default-route then
    pass
  elseif community matches-any (81:81) then
    pass
  endif
end-policy
RP/0/RSP0/CPU0:EC-XPTO1(config)#router rip
RP/0/RSP0/CPU0:EC-XPTO1(config-rip)# vrf XXX
RP/0/RSP0/CPU0:EC-XPTO1(config-rip-vrf)#redistribute bgp 34 route-policy XXX-bgp-to-rip
RP/0/RSP0/CPU0:EC-XPTO1(config-rip-vrf)#commit
% Failed to commit one or more configuration items during a pseudo-atomic operation. All changes made have been reverted. Please issue 'show configuration failed' from this session to view the errors
RP/0/RSP0/CPU0:EC-XPTO1(config-rip-vrf)#ex
RP/0/RSP0/CPU0:EC-XPTO1(config-rip)#ex
RP/0/RSP0/CPU0:EC-XPTO1(config)#sh configuration failed
Thu Mar 15 14:10:06.587 WET
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
router rip
vrf XXX
!!% Could not find entry in list: Policy [ccam-bgp-to-rip] uses the 'community' attribute. There is no 'community' attribute at the rip redistribution attach point.
End
Can you help please?
Thanks for all.
JoaoPatrx
Since your route-policy uses communities, which are invalid to rip, you cannot attach it to router rip.
As a workaround you can match your community routes and tag them using table-policy on router bgp. Then on router rip you can redistribute bgp with the route-policy of your desire. Here's an example, matching bgp routes with community 99:99 and tag them with 1234 then redistribute to rip.
community-set client-to-rip
   99:99
end-set
route-policy client-to-rip
   if community matches-any client-to-rip then
     set tag 1234
   else
     pass
   endif
end-policy
route-policy client-to-rip-bgp
   if tag eq 1234 then
     pass
   else
     drop
   endif
end-policy
router bgp 66666
  vrf client
   rd 66666:2222
   label-allocation-mode per-ce
   address-family ipv4 unicast
    maximum-paths eibgp 2
    table-policy client-to-rip
    redistribute connected
    redistribute static
    redistribute rip
router rip
  vrf client
   interface GigabitEthernet0/2/0/1.8
   timers basic 15 45 45 50
   redistribute bgp 66666 route-policy client-to-rip-bgp
   redistribute static
   default-metric 1
JoaoPatrx
   99:99
end-set
     set tag 1234
   else
     pass
   endif
end-policy
   if tag eq 1234 then
     pass
   else
     drop
   endif
end-policy
router bgp 66666
  vrf client
   rd 66666:2222
    redistribute static
    redistribute rip
router rip
  vrf client
   redistribute static
   default-metric 1
Joao,
Thank you for all
Reguards
