Serial number of power module in snmp
FedeSaraullo
Hello, i have a question,
I can´t get the serial numbers of the power modules of snmpwalk.
I can see the serial numbers of other LC and modules, but not of power supplies.
I revised in entPhysicalSerialNum mib (1.3.6.1.2.1.47.1.1.1.1.11).
It´s possible? or do i have a problem with the snmp configuration? or other thing is occuring?
Thanks a lot
correct, you need minimally the sysowner on the community string to "expose" certain system variables and OID's via snmp:
https://supportforums.cisco.com/document/86836/asr9000-monitoring-power-supply-information-snmp
if that provides the info you are after, I am happy too! :)
cheers!
xander
xthuijs
hi,
I am sorry the entity-mib doesn't fill out the serial number for the power modules.
cli (or ksh) like commands are the option here only...
xander
Hi, thanks for your request. The problem's solution was to change an attribute of snmp-server command, configure it as systemowner. With this, you can see all hardware system of device.
For example
snmp-server community RO systemowner acl 1
cheers!
xander
Thanks Alexander, i ´ll see you in other case!!
