SNMP data collection of interface with peaks and abrupt decrease
mromanini
Good evening.
I have an issue getting snmp data from varios interface and nodes. We have ASR9k  6.2 showing values like zigzag. For example i have an interface police rate at 4 gbps against a upstream provider and some times y get a lecture like 3.5 gbps and the next one of 4.5 gbps. Its seems like it is triying compensate the previos reading with a higher value. I have tested it with ifmib caching and without but the problem persist.
In the begining I thought it could be a problem of zabbix but it is not. I made a script that polls every 5 minutes and I get the exact sames results that zabbix does.
I have a multivendor environment and this behavior its only seen with ios xr.
Any sugestions? thank in advance
0 Replies 0
