As I checked Cisco Live! power points, Tomahawk NPU supports 64K pppoe session. Some Questions here:
1- A99-48x10GE-1GE-SR has two NPUs, does this mean I will have 128K pppoe session on this card?
2- Also it was mentioned the TCAM capacity for ipv4 is 96K,Is this applicable for this card as well?
3- Consider I want to provide Dual stack services, then will the capacity be half(TCAM and BNG capacity)?
4- As I checked the Cisco Configurator, For 8x100GE-SR there is a dedicated BNG license, while there is no dedicated BNG license for 48x10GE. What does this means? If I use this cards and do not use ether-bundle for PPPOE AC, then will The router work in LC mode for PPPoE sessions or RP mode?
Thank you
