TACACS access issue within VRF on cisco XR 4.3.4
Eric Guo
hi all,
we would like change our TACACS access path from global RT into VRF RT, but we are failed for access TACACS server as shown below error message.
tacacs/tacacs_lt 0/RSP0/CPU0 t10 No appropriate server found - 'TACACS' detected the 'fatal' condition 'Server not found'
we could ping 192.168.0.1 within vrf MGMT from loopback 1, but no sure why it is saying no route to tacacs server.
ping vrf MGMT 192.168.0.1 source 10.10.18.99-successful
here is configuration for tacacs setup, could someone share with your thought?
interface Loopback1
vrf MGMT
ipv4 address 10.10.18.99 255.255.255.255
aaa group server tacacs+ tttt
server 192.168.0.1
vrf MGMT
aaa authorization exec default group tttt local
aaa authentication login default group tttt local
tacacs source-interface Loopback1 vrf MGMT
tacacs-server host 192.168.0.1 port 49
key 7 xxxxxxxx
control-plane
management-plane
out-of-band
vrf MGMT
interface Loopback1
allow SSH peer
address ipv4 192.168.0.0/24
allow SNMP
line default
exec-timeout 50 0
access-class ingress VTYACL-IN
thanks,
Eric
xthuijs
hi eric,
you have the right config there. Possibly, you want to make the server private in the server group
and remove the public definition.
if that doesnt do the trick.
kick the aaa and tacacs process and capture some tac debugging and mainly io to see what tableID is picked for the server.
cheers!
xander
Thanks Xander for vaildating.
Yes, we reset tacacs server process, and it was working after around 8 hours later. I still have no idea what is the reason.
thanks,
Eric
hi eric,
yeah in XR 434 the config sequence is a bit "sensitive". So when things are not configured/committed in the right order, the tacacs process "assumes" for instance the default routing table, because it didn't see the vrf from the server group.
so things continue to work in the wrong tableID until that process restart which effectively re-evaluates the config.
that deficiency is taken care of in 51 onwards btw.
cheers!
xander
thanks Xander, good to know. Eric
