tftp on ASR9010
hi,
Few packages are missing one of my remote ASR9010, Please help me how I can copy files from router to other router.
TFTP Server Router:
RP/0/RSP0/CPU0:ASR9010-1(config)#tftp ipv4 server homedir disk0:
TFTP Client:
RP/0/RSP0/CPU0:ASR9010-1#copy tftp: disk0:
Sun Oct  7 15:42:14.057 KSA
Address or name of remote host [10.0.0.5]?
Source filename [/tftp:]?
Copy operation aborted
RP/0/RSP0/CPU0:IDC0100PER02#
RP/0/RSP0/CPU0:IDC0100PER02#copy tftp: disk0:
Sun Oct  7 15:42:20.710 KSA
Address or name of remote host [10.0.0.5]?10.0.0.6
Source filename [/tftp:]?asr9k-video-p-4.0.3
Destination filename [/disk0:/asr9k-video-p-4.0.3]?
Copy : Destination exists, overwrite ?[confirm]
Accessing tftp://10.0.0.6/asr9k-video-p-4.0.3
C
320 bytes copied in      0 sec
RP/0/RSP0/CPU0:ASR9010-1(admin)#copy  tftp: disk0:
Sun Oct  7 15:54:48.070 KSA
Address or name of remote host [10.0.0.6]?
C
RP/0/RSP0/CPU0:ASR9010-1(admin)#install add disk0:asr9k-video-p-4.0.3
Sun Oct  7 15:51:46.629 KSA
Install operation 15 '(admin) install add /disk0:asr9k-video-p-4.0.3' started by user 'admin' via CLI at 15:51:46 KSA Sun Oct 07 2012.
Error:    Cannot proceed with the add operation because the file '/disk0:asr9k-video-p-4.0.3' is not a pie file.
Error:    Suggested steps to resolve this:
Error:     - check the name of the pie.
Error:     - check the location of the pie.
Install operation 15 failed at 15:51:47 KSA Sun Oct 07 2012.
file size is worng.
10084787    -rwx  320         Sun Oct  7 18:38:56 2012  asr9k-video-p-4.0.3
best regards
tahir
Nicolas Fevrier
Hi Tahir,
"Install add" operation can only be performed with pie files...
(5610073     -rwx  600507      Sun Oct  7 19:39:49 2012  asr9k-video-p.pie-4.0.3)
You probably tried to copy a directory structure "drwx" instead of a file.
Cheers,
N.
Nicolas Fevrier
Hi Tahir,
Cheers,
N.
