vsm built-in 4 x 10G ports
samiwehbi
Dears,
concerning the VSM built-in 4 x 10G ports as per guide below they are not currently used, i just need to confirm this issue, and if any information on future use (VSM sync, etc. ??)
The four 10 Gigabit Ethernet SFP+ module ports and their associated LEDS on the VSM card are not supported in the current release.
Link: http://www.cisco.com/c/en/us/td/docs/routers/asr9000/hardware/vsm_line_card/installation/guide/vsmig/vsmig_install.html#58562
Sami
Nicolas Fevrier
Hi Sami,
you are correct, the ports are not useable. We currently don't have any use-case for them in the roadmap.
Kind regards,
N.
Hi Nicolas,
thanks for the confirmation.
Sami
Hi Nicolas,
I have going through your following post:
https://supportforums.cisco.com/document/12885281/installation-steps-arbor-tms-asr9000vsm
may you please share with me a sample bgp configuration after finishing setup the installation as above?
Also is it necessary to use bgp flow spec?
thanks,
Haitham Jneid
Haitham,
Besides the TMS software on the ASR9K VSM card, you will also need to run the Arbor Peakflow SP on a UCS VM for this solution to work.
There is no specific configuration required for BGP, just a regular iBGP session between the ASR9K and SP or TMS.
The Arbor user guide has a lot of information on the setup of the SP and BGP.
Vincent
