What snmp OID to use to monitor control-plane of router
Lasandro Lopez
Hi there!
I've applied policy-maps on control-plane, based on cisco recomandation.
Now i need to know, what snmp OID i've to use to monitor them (i'm using zabbix)
Let me know.
Regards!
mivens
If you are using IOS which uses a policy-map to configure Control Plane Policing then you are asking in the wrong place as this forum is for IOS-XR not IOS but you can poll objects in the CISCO-CLASS-BASED-QOS-MIB::cbQosPoliceStatsTable (for example cbQosCMDropByte64, cbQosPoliceExceededByte64, cbQosPoliceConformedByte64).
If you mean you have changed the LPTS policers to help protect the control-plane in IOS-XR then I believe there is currently no support for polling the counters via SNMP. See the section on monitoring in Xander's document https://supportforums.cisco.com/document/93456/asr9000xr-local-packet-transport-services-lpts-copp
yeah LPTS has no defined MIB, but we are getting XML support for that in XR 531.
regards!
xander
