Walkthrough Wednesday: Enhancing Meeting Quality with Webex Edge Connect - Recording now available!
Cole Callahan
In our upcoming Walkthrough Wednesday event (Feb. 17, 1-1:45 PM EST), Glen and Richard will include demos and covering the following:
- Solution overview
- Equinix Portal Demo
- Routing and NAT operations
- Webex Traffic Flows
- DEMOS: Router configuration: BGP, NAT, QoS, Route distribution
If you have any questions about the event, feel free to respond to this post. Our TMEs are here to help!
Response Signature
9 Replies 9
ricmurph
The Cisco Preferred Architecture documentation is located at https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/uc_system/design/guides/PAdocs.html. Within the Webex Edge section, there is an updated Edge Connect document (July 2021).
Cole Callahan
Hello all, the event recording is now available below
Response Signature
Thanks for hosting.  THis was a great session.  Will the deck be coming also?
Hi @nathanaelb ,
Thanks for attending the event. We are glad you were able to join us.
This post has been updated and the slide deck is now attached to the main post above.
Response Signature
sean.eckton
Level 7
Level 7
I noticed on the web site for this solution, there are two partners that can provide the connectivity but only one of them was mentioned today.  What about PacketFabric?  Any experience with them?
PacketFabric uses Equnix to connect to Webex for Edge Connect also.  All Edge Connect links need to come through Equinix to Cisco Webex in the Webex Edge Connect solution.
ahmad_tamneh
Level 4
Level 4
Quality and security, I would love to see how Cisco Webex maintains both without compromise one feature over the other!
Cole Callahan
Once you click on the event, it will say it has not been started yet, and then it will prompt you with this screen, where you can add it to your calendar directly! Screen Shot 2021-02-02 at 3.36.14 PM.png
Response Signature
lgreen
Is there a way to add this to my calendar without creating a manual event?
