ACI Endpoint is not pinging
Dinu M U
One of my ACI endpoint is not pinging. Endpoint is getting learned on LEAF interface, However it is not pining from ACI and vice versa.
LEAF113# show system internal epm endpoint ip 10.242.237.92
MAC : 0050.5698.90b4 ::: Num IPs : 1
IP# 0 : 10.242.237.92 ::: IP# 0 flags :
Vlan id : 25 ::: Vlan vnid : 9694 ::: VRF name : PROD:Hybrid
BD vnid : 15990736 ::: VRF vnid : 2981888
Phy If : 0x1a001000 ::: Tunnel If : 0
Interface : Ethernet1/2
Flags : 0x80004c04 ::: sclass : 32782 ::: Ref count : 5
EP Create Timestamp : 05/20/2019 12:24:42.524096
EP Update Timestamp : 05/20/2019 12:25:21.033163
EP Flags : local|IP|MAC|sclass|timer|
5 Replies 5
sarabsin
Can you ping from the Endpoint to BD gateway ip address which is is in same subnet as Endpoint?
How did you try to ping an endpoint?
Leaf# iping 10.242.237.92 -V PROD:Hybrid
If endpoint is not replying, probably firewall (on server) is blocking echo-requests.
Hope it helps
yuzaimee_yahaya
Uisng iping, i get the reply.
However when I do ping command, the endpoint not reply.
Let say 1 endpoint is on vlan 26, this endpoint can communicate on ip within vlan 26 only. Other vlan will failed to ping to this particular endpoint only. While the other ip from vlan 26 is able to pinged from different segment.
Any ideas?
Endpoint is IBM LPAR AIX
Hi @yuzaimee_yahaya ,
This is an old and seemingly dead question.  Would you mind asking it as a NEW question while I think about a reply
RedNectar aka Chris Welsh.
Thiago Galdino
Try this
Leaf103# iping -V VRF_NAME -S BD_IP_address 10.242.237.92
If the endpoint doesn't ping probably this endpoint have a firewall active.
