aci lab for poc
gavin han
we want to build ACI lab for poc. we have leaf switches, need spine & apic. which spine model and APIC will be cheapest?
RedNectar
To build an ACI POC lab, You will need a minimum of:
  • 2 x Leaf Switches
    • [If using existing switches, 2 x ACI Code upgrades]
  • 1 x Spine Switch
  • 1 x APIC
You say you have Leaf Switches, but you'll need to purchase ACI Code for those switches - assuming they are running NX-OS now.  Not sure of the price of the Software, but from memory it used to be in the ballpark of $US10K per switch list price.
So you may actually be better off purchasing a lab kit bundle rather than individual parts if they are still available (Here's a link to an old brochure - NOT on CIsco website).
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
RedNectar aka Chris Welsh.
RedNectar
  • 2 x Leaf Switches
  • 1 x Spine Switch
  • 1 x APIC
I hope this helps
