ACI leaf doesn't send dhcp discover
config
Hi team,
I can't to add my first leaf to the apic.  When i enter the tcpdump commad for the kpm_inb interface , i get nothing.
(none)# tcpdump -ni kpm_inb port 67 or 68
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on kpm_inb, link-type EN10MB (Ethernet), capture size 262144 bytes
^C
0 packets captured
0 packets received by filter
0 packets dropped by kernel
When i check the errors on the switch using moquery -c faultInfo command, i get the following error "F0341: fltDhcpClientIfIfOperStFailed" . I have already tried rebooting  the switch, but that didn't help.
Could you help me to find the reason?
@cisco ACI
18 Replies 18
@Robert Burns thanks for your help.
brocklesner7800
Just here, to read
Robert Burns
Can you also confirm that no other devices are connected to the Leaf other than the APIC(s) and/or Spines.
Robert
Yes, the other devices aren't connected to the Leaf
