ACI Multi Site considerations
faizal_vi
Hi ,
We are planning to deploy our redundant DC with another ACI cluster. I would like to know the things which need to considered while deploying the ACI cluster. This will be integrated using MSO.
My main questions are with regard to the Fabric Name, Fabric ID, POD ID , TEP POOL ,VLAN ID and BD Multicast address. Are these values significant to the local cluster only or it should be different while deploying Multi Site?
Thank you.
Robert Burns
Faizal,
We have some great "Ask the Expert" sessions on this topic.  Please see here: https://learningnetwork.cisco.com/s/learning-plan-detail-standard?ltui__urlRecordId=a1c3i0000007oRWAAY&ltui__urlRedirect=learning-plan-detail-standard
One session I'd recommend is titled: Architecture Transformation Planning: Multi-Site for Cisco ACI
For the resources in question, I'd recommend the following:
Fabric Name: Should be unique
Fabric ID: Should always be "1"
POD ID: All fabrics must start with ID 1
Infra TEP POOL: These can be the same as other fabrics, but its our best practice to keep the subnets unique for easier identification
Infra VLAN ID: Our defacto recommendation is 3967, but can be any VLAN ID that you can allocate for ACI use.  Will not be used for cross-site communication and should be ensured not to be a reserved VLAN (internal system VLAN) on any of your other platforms.
BD Multicast address: Should be unique
For some of the IDs/Subnets above, try to come up with a naming plan.  As you hopefully know, MultiSite introduces the concept of a "Site ID", which is used to represent your various sites and populate translation tables for inter-site communication.  I recommend building your Site ID into the other IDs if/where possible.
Ex.  (Keep in mind your numbering system should be mindful of your current & future growth scale.  The example below would account for 98 Leafs per pod and 8 Spines max)
Property  Site1 Site2 Site3
Site ID (MSO) 1 2 2
Fabric ID (APIC) 1 1 1
Infra TEP Pool  10.1.0.0/16 10.2.0.0/16 10.3.0.0/16
Infra VLAN 3967 3967 3967
Spine Node IDs
Pod1: 111-119
Pod2: 121-129
Podx: 1x1-1x9
Pod1: 211-219
Pod2: 221-229
Podx: 2x1-2x9
Pod1: 311-319
Pod2: 321-329
Podx: 3x1-3x9
Leaf Node IDs
Pod1: 1101-1199
Pod2: 1201-1299
Podx: 1x01-1x99
Pod1: 2101-2199
Pod2: 2201-2299
Podx: 2x01-2x99
Pod1: 3101-3199
Pod2: 3201-3299
Podx: 3x01-3x99
BD MCast Range 225.1.0.0 225.2.0.0 225.3.0.0
Robert
Robert Burns
Faizal,
Site ID (MSO) 1 2 2
Spine Node IDs
Pod1: 111-119
Pod2: 121-129
Podx: 1x1-1x9
Pod1: 211-219
Pod2: 221-229
Podx: 2x1-2x9
Pod1: 311-319
Pod2: 321-329
Podx: 3x1-3x9
Leaf Node IDs
Pod1: 1101-1199
Pod2: 1201-1299
Podx: 1x01-1x99
Pod1: 2101-2199
Pod2: 2201-2299
Podx: 2x01-2x99
Pod1: 3101-3199
Pod2: 3201-3299
Podx: 3x01-3x99
Robert
I have some questions for the Multisite
1-the BD multicast in site-1 255.1.0.0/16 and for the site-2 255.2.0.0/16 correct ?
 2-the tenant and the VRF can be the same between two sites.
3-If the GW for the all servers in the two sites is the FW and the ACI in the two sites is L2 so if i will do ISN between two sites , can i stretch one EPG in site-1 to one EPG in site-2 for VM motion ?
