APIC, LEAF, and SPINE SSH Timeouts and Logon Attempts
Is there any way to set the SSH timeouts for the APIC, LEAF, and SPINE devices? I can't seem to find the commands in the GUI or the CLI...
Also, the default logon attempt max is set to 5 is there any way to configure max logon attempts to 3?
Confirmed that "GUI idle timeout" affects SSH on both APIC & Switches.
Robert
8 Replies 8
Robert Burns
Login attempts & GUI timeouts are managed under Security Management:  Admin > AAA > Security Management
Robert
GUI timeouts are managed there, and I have already set them. I am looking to configure SSH timeouts and logon attempts.
Also, there is no setting under security management for login attempts (at least not that I can see).
Thanks.
Apologies was looking at a different value.  I don't believe those two options are currently configurable (SSH timeout & login attempts).  Let me confirm with Eng and get back to you if this is possible or on the roadmap.
Robert
Thanks! I'd still like to know if they are currently configurable or not (that would help). Or if it is on the current road map.
Hi Robert - did you find any additional info? such as default value and if there is a roadmap?
Robert
Best trick I learned today, thank you Robert! Didn't know how to set the SSH timeout until today...
Peter
Thanks Robert!  I was able to bump up my webtoken timeout as a workaround for hitting Bug CSCux04425.  I will change the webtoken timeout back to default 600 (10 minutes) after finishing my upgrade.
