Citrix Netscaler VPX Integration with ACI
RahulShindeMM
Our team is working on a DC migration from traditional DC (With Nexus 7K as Core) to ACI.
In traditional network, we are using Citrix NetScaler VPX as our load balancer.
There are multiple applications in the current setup hosted on this load balancer.
We want to migrate this VPX to new data center's ACI setup.
We are aware that Citrix NetScaler can be integrated with ACI.
Now the applications which are currently hosted on the Citrix LB will be part of different Tenants in new setup.
Can we have a single VPX integrated with ACI which hosts applications with back end servers spread across multiple tenants?
balaji.bandi
As per ACI  Point of you.  EPG is the main important here if you assign a port group that device part of the EPG, EPG will have all the access
High level -
it's all how you design the setup and environment. If Citrix VPX EPG required all the backend servers access, then you put those servers into another EPG and give access to Citrix
Bear in Mind ACI is not a full-blown Firewall replacement here.
BB
