Multi-Site Hardware Requirements - Fixed form factor EX Spine
Claudia de Luna
I understand that EX class hardware is a requirement for Spines in a Multi-Site deployment.
Is there a fixed form factor EX class spine currently available and if not, is there an expected time frame?
Also, there is a spine capable EX line card for a 9500 but it looks like that is 100G only?  Is that correct or did I misunderstand?
Thanks in advance for the help & clarifications!
6 Replies 6
I just wanted to see if you found any answer to your question on fix chassis Spine supported for Multi-site?
Looks like after months still the only supported hardware is 9500 series with 100G line card!
Ehsan
Rick1776
Level 5
Level 5
Check out this Cisco live session.
https://www.ciscolive.com/online/connect/sessionDetail.ww?SESSION_ID=95450&backBtn=true
New FX non modular spine (9364C,
64x40G/100G ports) will be supported for
Multi-Site in Q1CY18 timeframe
Rick1776
Level 5
Level 5
Just found out that the multi-site will be supported with ACI ver 3.1 not 3.0.
You mean even with 9500 series you have to wait for version 3.1 ?  I think the Multi-Site VM appliance is already available for download and deploy for version 3.0
9500 spines are supported for multi-site in 3.0 as long as you have the gen2 line card (-EX or -FX).
-JW
No, my comment was only referring to the new baby spine Nexus 9364.
