Nexus 9396
pasa barnett
I am attempting to convert a Nexus 9396 from ACI to standalone mode. i've followed the some online documentation. The image is in the bootfash:
n9000-dk9.6.1.2.I3.4b.bin. I configure the switch to boot the image. and I get the following error. Is there a step I am missing?
Filesystem type is ext2fs, partition type 0x83
No autoboot or failed autoboot. falling to loader
21 Replies 21
aleccham
Pasa,
What does the switch prompt state at this point, assuiming you have console access to the switch?
Did you follow these steps when attempting to convert?
1)      Copy standalone image to bootflash:
2)      Reload the box
3)      Keep pressing Ctrl+C when box is coming up to stop at loader prompt
4)      Cmdline recoverymode=1
5)      Boot <standalone image>
6)      It will stop at kickstart
7)      Perform ‘init system’
8)      Perform ‘write erase boot’
9)      Reload the box
10)   It will stop at the loader & load the standalone image, it will take through initial setup diagloue/poap as needed
Tom,
loader > dir
bootflash::
  aci-n9000-dk9.11.1.3f.bin
  auto-k
  disk_log.txt
  mem_log.txt.old.gz
  .patch
  .patch-issu
  mem_log.txt
  virtual-instance
  virtual-instance.conf
  virt_strg_pool_bf_vdc_1
  scripts
  auto-s
  diag_bootup
loader >
Can you please try this on the console and log the terminal window output for the reload and attach to this thread.
Loader > cmdline init_system clear_config clear_log
Loader > boot bootflash://n9000-dk9.6.1.2.I3.4b.bin
T.
still stuck at loader prompt
here is the error I am receiving,
Trying to read config file /boot/grub/menu.lst.recovery from (hd0,4)
Please try the following:
Loader > boot bootflash://aci-n9000-dk9.11.1.3f.bin
Does the switch boot back into ACI mode?
waiting.. it's going through some process. see below
This filesystem will be automatically checked every 26 mounts or
180 days, whichever comes first.  Use tune2fs -c or -i to override.
Erasing 128 Kibyte @ 60000 -- 100 % complete
Erasing 128 Kibyte @ 20000 -- 100 % complete
Erasing 128 Kibyte @ be0000 -- 100 % complete
Erasing 128 Kibyte @ 24c0000 -- 73 % complete
yes, the switch booted into ACI mode
lets change it from here:
* use "admin" and no password to login into switch (assumption is switch is in discovery mode).  If not is discovery, login with "admin" and admin password.
* verify n9000-dk9.6.1.2.I3.4b.bin is in bootflash in ACI mode
* CLI commands
clear-bootvars.sh
setup-bootvars.sh n9000-dk9.6.1.2.I3.4b.bin
* Verify bootvars have changed
cat /mnt/cfg/0/boot/grub/menu.lst.local
cat /mnt/cfg/1/boot/grub/menu.lst.local
* type "vsh".  Then "reload".  "y" to reload
T.
ok, switch is rebooting.
Now I have a second 9k where I did the system_init and blew out the ACI image. I cannot copy the image back into the my usb. The is no copy from the loader prompt. there has to be a way to copy an image into the bootflash. Do you know the command?
And, the original switch booted into loader> again.
Am I missing the kick-start image. could that be the problem?
It appears Pasa was running into:
CSCus90279
We got on a webex and we got his switches successfully converted.
T.
Can you elaborate on the fix, I have a 9372PX-E with similar symptoms. Switch rebooted to loader> prompt for unknown reason. Rebooting switch results in error error no bootflash. Trying to load an nxos image from USB results in error Boot disk not found. If I load an ACI image from USB it goes through a bunch of Erasing 128 Kibyte @... then I'm at the bash-4.2# prompt and eventually it reboots because it's "Dazed and confused". I don't know what to do next. How can I format bootflash from the bash prompt?
micgarc2
Yan,
Try following these steps:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/upgrade/guide/b_Cisco_Nexus_9000_Series_NX-OS_Software_Upgrade_and_Downgrade_Guide_Release_6x/b_Cisco_Nexus_9000_Series_NX-OS_Software_Upgrade_and_Downgrade_Guide_Release_6x_chapter_010.html#task_938EF40E07D640DD8EC6707186B18863
Let me know if you are still having issues.
