Remote Leaf Uplink interfaces
AirBorn
Hello Experts
Does  Remote leaf uplinks supports 1GE GLC-T modules?
Robert Burns
6 Replies 6
Robert Burns
https://www.cisco.com/c/en/us/solutions/collateral/data-center-virtualization/application-centric-infrastructure/white-paper-c11-740861.html
"A minimum of 100 Mbps bandwidth in the IP Network. Starting from Cisco ACI Release 4.2.4, the requirement has been lowered to 10 Mbps of bandwidth."
Robert
You'd have to ensure the uplink ports of the platform support a 1G GLC adapter.
Robert
AirBorn
Thank you for your feedback
My question was regarding the type of the remote leaf uplinks interface type
I have seen that document. I was a bit confused by the paragraph "1G or 10G connectivity from remote leaf switches to upstream Router" where it seems that only optical SFPs are supported as remote leaf uplinks.
So, the Remote leaf upstream links could also be electrical (RJ45) 1GE ?
As mentioned above, as long as the platform supports it, no issues.  You didn't mention the switch platform, so can't confirm without that info.
Robert
AirBorn
N9K-C93108TC-FX-24, we are  using QSA adapter
Robert Burns
Yes, it's supported.
Ref: https://tmgmatrix.cisco.com/?dr=21&os=2&npid=148
Robert
