Replacing spine by a different spine model
ANAKIN_TN
HELLO,
i have cisco aci fabric with many pords, one of my pods are made by 2 x Cisco Nexus 9332C spines connecting 16 leaves with 4 uplinks for each leafs.
I already used all the ports of the spines and i want to replace the 32 ports Cisco Nexus 9332C  spines by Cisco Nexus 9364C 64ports  spines that i already buy  .
How can i proceed withiut impacting the production and the traffic in the fabric ?
thers is any restriction about upgrading the spine hardware ? knowing the if i will replace using the RMA method or like im replacing a broken spine the pod will works for a while with 2 spine having different harwares .
Thank you in advance for your help .
ANAKIN_TN
Hello Guys,
I have new update about this, the cisco TAC says that there is no problem replacing this by an another spine we just must keep te same port mapping.
9 Replies 9
M02@rt37
Hello @ANAKIN_TN,
What is your Leaf's model ?
What is your oversubscription ratio now ?
Best regards
What is your Leaf's model ? the actuals are  Cisco Nexus 9332C
What is your oversubscription ratio now ? 3:1
Hello @ANAKIN_TN,
Are you sure as Leaf ?
Best regards
soory my leaf models is C93240YC-FX2
ANAKIN_TN
Hello Guys,
Ok @ANAKIN_TN
Thabks for your feedback
Best regards
Hi M02@rt37
A side question, can the C9500 serve as spine for Nexus 9300 leaf?
Any back draw on that?
Hello @ANAKIN_TN
In term of design, Catalyst switches are typically used for campus and enterprise deployments, while Nexus Switches are more common in Data Cnnter environments.
Best regards
Hello @ANAKIN_TN ,
have you replaced the spine in your environment?
If Yes, then please assist me by providing pre-requisite and instruction about replacement.
Have you faced any problem like traffic loss while replacing the spine? What time required for new spine to join the fabric after configuring node ID and hostname?
After one spine goes down then all workload shift to the other spine which is in production. So what is the behavior of that active spine? Its memory and CPU utilization.
Please assist
