Why we have used UDP to encapsulate VxLAN , how the receiver will deal with out of order packets ?
RedNectar
Hi @Rishabhkumar8045 ,
The receiver will NEVER get out of order packets. So it's not a worry.  This is because every packet for every flow is sent on the same path, the path being calculated from a hash of these five things:
  1. Source IP,
  2. Destination IP,
  3. Source UDP Port,
  4. Destination UDP Port and
  5. protocol (which of course is UDP).
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
RedNectar aka Chris Welsh.
RedNectar
  1. Source IP,
  2. Destination IP,
  3. Source UDP Port,
I hope this helps
