Application Slowness through ACE 4710
swizzguy3
We are struggling with an issue where a user can run a report directly from the server but not from ACE loadbalanced url.
  • Report run via Individual Web server URL’s
    • The report takes less than 20 minutes (average 15 minutes) to fetch and return the data. This is observed 9 out of 10 times.
  • Report run via ACE Load Balanced URL
    • The report keeps on running for more than 20 minutes and never completes. The front end keeps showing report is running.
  • The data in general when tested directly by running queries against the database (bypassing the platform) completes in 15-18 minutes
  • The network connectivity for each and every ports involved (Loadbalancer/Servers) have been throulgly checked.
Please advise what is the best way to troubleshoot this issue.
Thx
Ahmad
6 Replies 6
Cesar Roque
Level 4
Level 4
Hi Muhammad,
Paste your configuration to have a better picture.
Is the same behavior with any browser or OS?
Cesar R
ANS Team
--------------------- Cesar R ANS Team
Jorge Bejarano
Level 4
Level 4
Ahmad,
Is this for http/https?
Yes, please paste your current configuration.
Jorge
Here is my current configurations.
probe http ping.htm
  port 80
  interval 5
  faildetect 2
  request method head url /ping.htm
  expect status 200 200
rserver host ttdcsrv1617
  ip address 10.36.172.65
  inservice
rserver host ttdcsrv1618-sandapp
  ip address 10.36.172.58
  inservice
rserver host ttdcsrv1714-sandapp
  ip address 10.36.172.41
  inservice
rserver host ttdcsrv1960
  ip address 10.36.188.69
  inservice
serverfarm host appbo
  probe ping.htm
  rserver ttdcsrv1617 80
    inservice
  rserver ttdcsrv1618-sandapp 80
    inservice
  rserver ttdcsrv1714-sandapp 80
    inservice
  rserver ttdcsrv1960 80
    inservice
parameter-map type connection 3600-seconds
  set timeout inactivity 3600
sticky ip-netmask 255.255.255.255 address source appbo
  timeout 20
  serverfarm appbo
class-map match-all appbo
  2 match virtual-address 10.36.253.245 tcp eq www
policy-map type loadbalance first-match appbo-l7slb
  class class-default
    sticky-serverfarm appbo
policy-map multi-match int63
  class appbo
    loadbalance vip inservice
    loadbalance policy appbo-l7slb
    loadbalance vip icmp-reply active primary-inservice
    connection advanced-options 3600-seconds
Ahmad,
What version are you using?
Can you upload these outputs?
# show service-policy int63 class-map appbo detail
# show stats http
#show resource usage
#show license brief
Also the configuration for the interface.
Has this ever worked before?
Why do you have a low timeout for your sticky configuration?
If you clear the cookies of the browser and turn off some of the servers to test only with one, do you have the same behavior?
In your tests, are you trying to the same type of query to your database? I mean do you see the problem if you try to update/delete/select in the database?
What are the servers? Oracle, SQL server, MS Access?
Jorge
Hello Jorge,
  Here is my response below.
What version are you using? Version A4(2.3a)
Status     : ACTIVE
Description: -----------------------------------------
Interface: vlan 1 62 63 155 409
  service-policy: int63
    class: appbo
     VIP Address:    Protocol:  Port:
     170.116.253.245 tcp        eq    80
      loadbalance:
        L7 loadbalance policy: appbo-l7slb
        VIP ICMP Reply       : ENABLED-WHEN-PRIMARY-SF-UP
        VIP State: INSERVICE
        VIP DWS state: DWS_DISABLED
        Persistence Rebalance: DISABLED
        curr conns       : 0         , hit count        : 136348
        dropped conns    : 21
        conns per second    : 0
        client pkt count : 4579400   , client byte count: 1054651106
        server pkt count : 6006908   , server byte count: 7506886155
        conn-rate-limit      : -         , drop-count : -
        bandwidth-rate-limit : -         , drop-count : -
        L7 Loadbalance policy : appbo-l7slb
          class/match : class-default
            LB action: :
               sticky group: appbo
                  primary serverfarm: appbo
                    state:UP
                  backup serverfarm : -
            hit count        : 136348
            dropped conns    : 12
            compression      : off
      compression:
        bytes_in  : 0                          bytes_out : 0
        Compression ratio : 0.00%
                Gzip: 0               Deflate: 0
      compression errors:
        User-Agent  : 0               Accept-Encoding    : 0
        Content size: 0               Content type       : 0
        Not HTTP 1.1: 0               HTTP response error: 0
        Others      : 0
        Parameter-map(s):
          3600-seconds
# show stats http
+-------------- HTTP statistics -----------+
LB parse result msgs sent : 455403292  , TCP data msgs sent       : 2434371041
Inspect parse result msgs : 0          , SSL data msgs sent       : 1740205587
                      sent
TCP fin msgs sent         : 40338385   , TCP rst msgs sent:       : 22697825
Bounced fin msgs sent     : 3083341    , Bounced rst msgs sent:   : 2062455
SSL fin msgs sent         : 53021042   , SSL rst msgs sent:       : 89469
Drain msgs sent           : 260995432  , Particles read           : 749867347
Reuse msgs sent           : 0          , HTTP requests            : 413618855
Reproxied requests        : 232446464  , Headers removed          : 0
Headers inserted          : 105893583  , HTTP redirects           : 1485493
HTTP chunks               : 144637122  , Pipelined requests       : 42911599
HTTP unproxy conns        : 305776225  , Pipeline flushes         : 942
Whitespace appends        : 720        , Second pass parsing      : 0
Response entries recycled : 42882784   , Analysis errors          : 0
Header insert errors      : 49         , Max parselen errors      : 35941
Static parse errors       : 261401     , Resource errors          : 0
Invalid path errors       : 0          , Bad HTTP version errors  : 117
Headers rewritten         : 49         , Header rewrite errors    : 0
SSL headers inserted      : 0          , SSL header insert errors : 0
SSL spoof headers deleted : 0         , Unproxy msgs sent         : 305776279
HTTP passthrough stat     : 0
Has this ever worked before? YES but the issue is Intermittent
Why do you have a low timeout for your sticky configuration? NOT SURE. WILL HAVE TO CHECK WITH APP OWNERS IF WE CAN INCREASE THAT
If you clear the cookies of the browser and turn off some of the servers to test only with one, do you have the same behavior? Will try to perform this test with app owners
In your tests, are you trying to the same type of query to your database? I mean do you see the problem if you try to update/delete/select in the database? No Refresh is pretty quick.
What are the servers? Oracle, SQL server, MS Access? ORAGLE 11G.
Thanks for your help!
Ahmad,
Can you try something like below under your policy multimatch
policy-map multi-match int63 under your class
appbo?
parameter-map type http test
  persistence-rebalance
  set header-maxparse-length 65535
  set content-maxparse-length 65535
  length-exceed continue
Jorge
