how to configure css with two redudant L2 switches
ptrigueira
Question:
if i have one CSS to connect to a redundant datacenter(two routers and two core switches), how do i configure it so that the css provides service to both networks ?
regards
PT
jnantel
I believe this is a simple spantree issue, if both ports on your content switch are bridged to the same vlan, then spantree will decide which port to use.
You won't be able switch content on both l2 switcches at the same time.
Jonathan Nantel
Could you explain this behavior ?
How would this change if the scenario was 2 CSS boxes each plugged into a seperate L2 switch, but the same VLAN and with the L2 switches being connected to each other and the CSS boxes connected together via crossover for redundancy?
