Load Balancing behind firewall
new_networker
Can load balancing be done behind a firewall with CSS. For e.g. CSS (on the outside of the firewall) load balances on the servers connected to the DMZ of the firewall.
If so, should there be any performance issues. And what if the firewall had IPS functionality as well.
Regards.
It can be done. You need to make sure
1. Holes are punched in the Firewall form probe traffic (CSS -> Servers)
2. Return traffic from the servers should not Bypass the CSS. (Firewall should handover the responses from servers back to CSS). You can use source nat on CSS for this purpose.
Syed Iftekhar Ahmed
Syed Iftekhar Ahmed
