policy-map multi-match
ajay chauhan
Level 11
Level 11
Hi Guys,
I need explanation on multi-match policy on ACE. How does it work ?
Lets take this example-
policy-map multi-match CLIENT-VIPS
  class VIP1-80
    loadbalance vip inservice
    loadbalance policy VIP1-POLICY
policy-map type loadbalance first-match VIP1-POLICY
  class class-default
    serverfarm SERVERFARM1
class-map match-all VIP1-80
  2 match virtual-address 192.168.1.200 tcp eq http
This will work for sure looking for functional diffrence if I make POLICY CLIENT_VIPS to frist match,what difrence will come in this case. will it not just match class VIP1-80 and redirect request to serverfarm.
Or this is something where multiple class can be called under CLIENT_VIPS like Inspection ?
Ajay
No its not..
I have 2 different policies VIP1-POLICY1 & VIP1-POLICY2 attached to each class. So you need separate class map to map it to different policies or different servers.
Siva
5 Replies 5
sivaksiv
Hi Ajay,
For policy-map commands that contain the  multi-match keyword, these commands specify that multiple sets of classes exist in the policy map and allow a multi-feature policy map. The ACE applies a first-match execution process to  each class set in which a packet can match multiple classes within the  policy map, but the ACE executes the action for only one matching class  within each of the class sets.
Siva
Hi Siva,
Can you please post any example where multiple actions are performed under multi-match policy ?
Ajay
HI Ajay,
Say if you have 2 class-maps on different ports 80 & 443
  class VIP1-80
    loadbalance policy VIP1-POLICY1
  class VIP1-443
    loadbalance policy VIP1-POLICY2
class-map match-all VIP1-443
  2 match virtual-address 192.168.1.200 tcp eq https
Siva
Hi Siva,
I think this can be done like-
class-map match-any VIP1-80
  3 match virtual-address 192.168.1.200 tcp eq https
I am looking for example with match-all /multiple actions.
Ajay
No its not..
Siva
