Panasonic PBX Dial Tone with SPA3102
dwest
I have successfully configured two SPA3102 to deliver remote dial tone.
(CO Line)----[SPA3102]===={IP Network}====[SPA3102]----Telephone
Works fine calls in or out using dial tone from a Rhino Channelbank.
This does not work so well
(Panasonic PBX Analog Extension Port)----[SPA3102}===={IP Network}====[SPA3102]----(CO Line)---->>PBX CO Port
I can call from another ext. in the PBX to the analog phone and it work, but it will not grab the line to make the call from the Remote ATA, or the local ATA. Has anyone dealt with this or a similar issue?
Thanks, Damon
rickfreitag
Damon:
The problem lies on the voltage.  Go to Voice/Info and check at PSTN Line Status the Line Voltage on hook, then off hook.  (In my case with a 308 it was -26 and -6) and then put the number between those (in my case, -16) in Voice/PSTN Line at International Control, Line-In-Use Voltage
Best regards,
Rick
