05-13-2013 01:01 AM - edited 03-21-2019 10:03 AM
Trying to detect a POTS hang up when dialing into SPA 3201 on a mobile -- want the hook back on when the mobile cuts out. Attached is a wave file which seems clearly to be 400 hz 0.375s on / off. Attached is the tone scipt in SPA 3201. Running latest firmware. Not sure why its not detecting. Tried for hours. My first time at this so I thought I'd run it past here in case there is something obvious I missed.
05-13-2013 11:35 AM
I note that the Cisco ATA Administration Guide lists the following specifications for disconnect tones used in various countries. It looks like the U.K. and New Zealand use a 400hz tone frequency. Have you tried that spec? Until you find the right specification you could always setup the SPA3102 to disconnect after a period of silence.
http://www.cisco.com/en/US/docs/voice_ip_comm/csbpvga/ata/administration/guide/ATA_AG_v3_NC-WEB.pdf
The Disconnect Tone Script values for various countries
follow:
US—480@-30,620@-30;4(.25/.25/1+2)
UK—400@-30,400@-30; 2(3/0/1+2)
France—440@-30,440@-30; 2(0.5/0.5/1+2)
Germany—425@-10; 10(0.48/0.48/1)
Netherlands—425@-30,425@-30; 2(0.5/0.5/1+2)
Sweden—425@-10; 10(0.25/0.25/1)
Norway—425@-10; 10(0.5/0.5/1)
Italy—425@-30,425@-30; 2(0.2/0.2/1+2)
Spain—425@-10; 10(0.2/0.2/1,0.2/0.2/1,0.2/0.6/1)
Portugal—425@-10; 10(0.5/0.5/1)
Poland—425@-10; 10(0.5/0.5/1)
Denmark—425@-10; 10(0.25/0.25/1)
New Zealand—400@-15; 10(0.25/0.25/1)
Australia—425@-13; 10(0.375/0.375/1)
