spa112 provisioning troubles 2: Static IP
Diego Betancor
with spc tool the example.xml file generated does not show any field to specify the Static IP, and the address and everything else.
We do not want DHCP. How can we do it with the provisioning frameset?
I have tried
  <Connection_Type ua="na">Static IP</Connection_Type>
  <Subnet_Mask ua="na">"255.255.255.0"</Subnet_Mask>
  <Default_Gateway ua="na">"172.26.0.1"</Default_Gateway>
and the spc compiles it, but the spa112 does not respond.
Thank you, Diego Betancor
Patrick Born
Hi Diego,
Thanks for reporting this issue. I've shared this information with both the SPC and documentation teams to have this corrected.
Here's what needs to be done to configure a static IP address on the SPA112:
In this example, I'll configure a static IP address as follows:
address: 192.168.12.44
Netmask: 192.168.12.255
Gateway: 192.168.12.254
http://www.sipura.net/xsd/SPA112" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.sipura.net/xsd/SPA112 http://www.sipura.net/xsd/SPA112/SPA112-1-1-0-010.xsd">
          st
          192.168.12.44:192.168.12.255:192.168.12.254
Use the http://deviceIPaddress/admin/config.xml command to display the device's XML configuration which you may find helpful.
Patrick
Patrick Born
Hi Diego,
          st
Patrick
Hi!
I have troubles spc with the tool I generate a configuration xml file based, which I edit, I have problems trying to generate the file.cfg, maybe I'm not using the appropriate command, because when a trying to upload the file, the ATA SPA112 show me: restore ties have failed.
Can I help me?.
Magally
Hil,
1. run the spc to look at the help menu (in windows I guess will be similar)
./spa112-1-1-0-010-spc-linux-i386
2.Generate a sample xml
/spa112-1-1-0-010-spc-linux-i386 --sample-xml mi_ejemplo.xml
3. Compile it:  (latter on you can change)
/spa112-1-1-0-010-spc-linux-i386 --xml mi_ejemplo.xml mi_ejemplo.cfg
4. Try to upgrade the ata. Now we have a problem because you upgrade with a server.
http://phoneIP/admin/resync?https://provServer/spa508.cfg
or
http://phoneIP/admin/resync?http://provServer/spa508.cfg
or
http://phoneIP/admin/resync?ftp://provServer/spa508.cfg
your server would be provServer, it can be your computer running a ftp server. Now this is kind of complicated and not thought for end users. If you are an end user much better to log in the sta.
(hope it helps)
Thank you Diego.
