SPA8800 how change LAN ip?
grzegorzniecka
Hello!
I have SPA8800 with predefined LAN ip with dhcp server on for 4 IPs.
can I change LAN ip?
nseto
Level 6
Level 6
No, the LAN side is fixed and is only to be used for direct connection from a pc to the aux port for config purposes to the unit.
I need to change this configuration because I have various vlans in my network and it's conflicting with my 192.168.0.0/24 segment.
Can it be changed?
