09-20-2017 08:03 AM
based on given link above , Cisco has release the documentation guide for Advanced SDK 11.6(1).
But somehow, I can't found the 11.6 SDK in DevNet.
The latest SDK on Devnet is 11.5.
https://developer.cisco.com/site/remote-expert-mobile/downloads/sdk/index.gsp
How to download REM Advanced SDK 11.6(1) for iOS, Android and web app ?
Please help.
Solved! Go to Solution.
09-21-2017 09:37 AM
Hi Subagyo,
The 11.6 SDKs are now available at https://developer.cisco.com/site/remote-expert-mobile/downloads/sdk/index.gsp
The web SDK is bundled within REM as the javascript files are available from the REM server.
Rob Doyle
09-20-2017 01:02 PM
Hi Subagyo.
11.6 is in the process of being released. If you speak to your contact from whom you got your Devnet account set up they should be able to give you more information.
Cheers,
Rach D
09-21-2017 09:37 AM
Hi Subagyo,
Rob Doyle
09-21-2017 07:55 PM
Hi Robert,
Thanks for your update.
Bagus
