Android assist sdk - startSupport() issue
oabutbul
my config is :
final AssistConfigBuilder builder = getBuilder();
builder.setServerHost("10.56.x.x"); // in my lab
builder.setServerPort(8443);
builder.setConnectSecurely(true);
builder.setAgentName("agent1");
and getting the errors below:
06-06 14:32:37.795 7221-7221/com.alicecallsbob.csdk.android.sample D/AndroidRuntime: Shutting down VM
06-06 14:32:37.798 7221-7221/com.alicecallsbob.csdk.android.sample W/System.err: java.lang.ClassCastException: android.widget.FrameLayout$LayoutParams cannot be cast to android.view.WindowManager$LayoutParams
06-06 14:32:37.799 7221-7221/com.alicecallsbob.csdk.android.sample W/System.err:     at com.alicecallsbob.assist.sdk.overlay.impl.AssistOverlayImpl.show(AssistOverlayImpl.java:100)
06-06 14:32:37.801 7221-7221/com.alicecallsbob.csdk.android.sample W/System.err:     at com.alicecallsbob.assist.sdk.core.AssistOverlayManager.showOverlays(AssistOverlayManager.java:273)
06-06 14:32:37.802 7221-7221/? W/System.err:     at com.alicecallsbob.assist.sdk.core.AssistCoreImpl.startAssistanceSession(AssistCoreImpl.java:301)
06-06 14:32:37.804 7221-7221/? W/System.err:     at com.alicecallsbob.assist.sdk.core.AssistCoreImpl.access$800(AssistCoreImpl.java:48)
06-06 14:32:37.805 7221-7221/? W/System.err:     at com.alicecallsbob.assist.sdk.core.AssistCoreImpl$3$1$1.run(AssistCoreImpl.java:352)
Thank Rich,
Right the sample app is not working as well.
I’m creating a sessionToken with the parameters below :
· Assist server – (10.56.x.x) – in my lab
· Port -8443
· Secure connection – yes
· Assist agent – agent1
Can we do a quick webex to figure out this issue ?
Orel
5 Replies 5
rimorgan
Can you provide a little more of your code? Does your app crash when you call StartSupport?
Cheers,
Rich
Thank Richard,
Yes, the app crashes, it’s happening even if I’m using the “Remote Expert Mobile” app (sample app that you’re provided), getting the same errors.
The settings are:
· Port -8443
For the agent I use the sample assist - https://rem-il-lab.cisco.com:8443/expertassist/agent/ (agent1/agent1)
Another q – regardless my issue – how can use sample agent assist with “correlation id” ?
Orel
Hi Orel,
Are you saying the sample app does not work for you, out of the box?
Are you trying to create your own sessionToken using the builder parameters above?
To use in correlationId mode, you should see a dropdown, top right, in the sample agent console where you enter the correlation id.
HTH,
Rich
Thank Rich,
· Port -8443
Orel
Hi Orel,
Sure, I'm based in the UK. Is there a time that suits? Maybe next week?
Cheers,
Rich
