06-12-2015 03:01 AM
Hi team,
When we integrate Jabber Voice and Video SDK with an enterprise intranet web site and the user is already logged in to this web site with the LDAP user, is it possible to use this login information to authenticate to Jabber SDK as well, in order to prevent the users to enter their username/passwords multiple times?
Thanks and regards,
Murat
06-12-2015 01:28 PM
Yes, it's possible. How to do it is another question altogether. I was working on that some time ago, but it got put on the back burner.
The key is avoiding a cross-site-scripting problem, which means enabling CORS on all the relevant servers and setting up the CORS URLs in CUCM.
06-15-2015 01:18 AM
Hi Nicholas,
So, I assume that if the web site which uses Jabber SDK resides in the same domain with CUCM, then we will not face cross-site-scripting problem, so we will not need CORS.
If so, how can we implement auto-login?
Thanks and regards,
Murat
06-16-2015 07:11 AM
Hi Murat,
The official word is that it's unsupported. I will continue to try to make it work in a sample application. If I ever discover how to get it working, I'll post sample code here. But even if I can, it won't be anytime soon.
06-16-2015 08:27 AM
Thank you very much Nicholas for your support.
Murat
