11-14-2014 06:11 AM
Chrome install as the default protocol handler for the tel protocol. After installing the Jabber client, the registry keys appear to be set properly to initiate Jabber for these links, but I get no response when the links are clicked. Xmpp links work fine.
11-14-2014 11:26 AM
Did you download and install the Chrome web extension?
11-14-2014 12:54 PM
Didn't think I needed to since I'm trying to initiate a call through the Jabber client, however I just tried it and it still does nothing.
11-14-2014 01:14 PM
You need the extension for Jabber voice/video. It became necessary when Chrome abandoned support for NPAPI.
But I misunderstood what you're trying to do. Somehow I misread that as installing the Jabber SDK, not the Jabber client, sorry.
I'm looking into the tel protocol issue. No luck so far, but I'll come back if I find anything.
11-14-2014 01:35 PM
[deleted old information]
11-14-2014 01:57 PM
Okay, sounds like you've done all the right things, and click-to-call on tel: is officially supported. I'm continuing to investigate.
11-18-2014 07:27 AM
The Jabber team reported that this is a Chrome issue. Chrome apparently takes ownership of tel: so it never gets to Jabber. You can use ciscotel: instead, and that should work (assuming everything else is configured properly) until Google fixes Chrome.
11-18-2014 09:56 AM
Thanks for the info. Does this mean that I just have to configure the registry to include ciscotel: or that the links have to be coded with ciscotel: instead of tel:? If I don't have control over how the links are coded then I guess I'm out of luck at this point.
11-18-2014 10:03 AM
The links have to be coded for ciscotel:
The registry should already have the ciscotel keys and values. I checked my test system, and they were automatically generated (they have the same values as the tel: registry entries).
I think there's a problem with Lync, too, but that could be solved with a Lync registry change. Unfortunately, a Jabber registry change won't fix this.
05-11-2016 05:17 AM
I have been fighting this for sometime and have found this to work and fix the problem.
This can be manipulated by deleting the 'Tel:' registry value at:
HKEY_LOCAL_MACHINE\SOFTWARE\Clients\StartMenuInternet\Google Chrome\Capabilities\URLAssociations\
