I'm using CUPI to try and updates a mailbox password.
So I PUT to https://srvcucn12s.nxodev.intra:443/vmrest/users/d65583a1-3da2-4fcd-b655-4beb896791df/credential/password
with this content
<Credential><Credentials>my password here</Credentials></Credential>
The response is
<?xml version="1.0" encoding="UTF-8" standalone="yes"?><ErrorDetails><errors><code>IMS_ERROR</code><message>Database communication error</message><DetailCode>-1</DetailCode></errors></ErrorDetails>
Setting the same password through the web interface works just fine. I know the id of the mailbox is correct because my software follows up this request with a bunch of others that pass (setting relay address, configure notifications devices, etc.)
CUC version is 12.5.1.12900-56
