01-27-2017 09:03 AM
I've been trying to create a simple Android application with the Remote Expert Mobile SDK, I followed the instructions in the developer tutorials here: https://developer.cisco.com/site/remote-expert-mobile/learn/developer-tutorials/
but I get this error when I try out the app:
can anyone help me out with this please?
Solved! Go to Solution.
01-27-2017 01:03 PM
Hi Andres,
Have you added device permissions outlined in the project setup link? In particular:
<uses-permission android:name="android.permission.SYSTEM_ALERT_WINDOW"/>
If so but you are using Android API 23 >= then follow advice at overlay - Unable to add window android.view.ViewRoot$W@44da9bc0 -- permission denied for this window type - Stack Overfl…
Rob
01-27-2017 10:08 AM
Hi Andres,
I think there is a mistake in the guide on https://developer.cisco.com/media/remote-expert-mobile-developer-tutorials/android-sdk/01-project-setup/project-setup.ht…
As well as the assist-android-sdk1.32.2.jar you should also add the fusionclient-android-sdk3.0.3.jar to the project libs folder.
Rob
01-27-2017 12:50 PM
Hi Rob,
adding the fucionclient-android-sdk3.0.3.jar worked but now I get a different error
I don't know what I did wrong, thanks in advance for your help
01-27-2017 01:03 PM
Hi Andres,
Rob
01-27-2017 02:18 PM
Hi Rob,
That solved the problem, thanks for your help. I've encountered other problems but won't try to solve them in this topic, I'll create a new discussion if needed.
