Remote Expert Mobile Android SDK. CSDK library not found
ajimenez2
I've been trying to create a simple Android application with the Remote Expert Mobile SDK, I followed the instructions in the developer tutorials here: https://developer.cisco.com/site/remote-expert-mobile/learn/developer-tutorials/
but I get this error when I try out the app:
can anyone help me out with this please?
Hi Andres,
Have you added device permissions outlined in the project setup link? In particular:
<uses-permission android:name="android.permission.SYSTEM_ALERT_WINDOW"/>
If so but you are using Android API 23 >= then follow advice at overlay - Unable to add window android.view.ViewRoot$W@44da9bc0 -- permission denied for this window type - Stack Overfl…
Rob
robdoyle
Hi Andres,
I think there is a mistake in the guide on https://developer.cisco.com/media/remote-expert-mobile-developer-tutorials/android-sdk/01-project-setup/project-setup.ht…
As well as the assist-android-sdk1.32.2.jar you should also add the fusionclient-android-sdk3.0.3.jar to the project libs folder.
Rob
Hi Rob,
adding the fucionclient-android-sdk3.0.3.jar worked but now I get a different error
I don't know what I did wrong, thanks in advance for your help
Hi Andres,
Rob
ajimenez2
Hi Rob,
That solved the problem, thanks for your help. I've encountered other problems but won't try to solve them in this topic, I'll create a new discussion if needed.
