ACI Contract Check (Host / Port)
PJ_Williams
I have been programmming my own Python script to list EPG's, The Associated Subjects and Filters. If push this a bit more I could maybe write a connectivity check between two EPG's.
Before I go down this road which will be painful (I am a Python noob) I want to check it does not exist. Here the goal.
Given two endpoints (IP or EPG) and a port, check if the required ACI contracts are present. Maybe only within the same VRF for now.
I know the APIC Gui has something, but it's slow, heavy and the output is confusing. I want something I can run as an app and provide a service. We are always having to check ACI contracts which means finding the EPG, looking at the contracts that "may" provide access based on the name, check they are setup as a cons/prov on the correct EPG'g and then checking filters.
Simply type 'contract_parser.py' from ibash (the regular shell on the Leaf)
Sergiu.Daniluk
I am not aware of a EP-to-EP checker, but here you have half of the intelligence, where you can check between two EPGs:
https://github.com/agccie/aci-contract-parser
In other words, you just need to build the EP-to-EPG verification, and then use the contract parser to check for existing contracts between epgs.
Hope it helps,
Sergiu
Thanks Sergiu, this looking amazing. On a different planet to anything I could create.
We are running ACI 4.2 and the python script is not in bootflash, has it been removed or moved somewhere else?
This is brilliant, I am sure many many companies would benefit form this but are not aware.
Many thanks.
