AUTOUPGRADE Parameter for Cisco TSP Silent Rollout is not working
Ali Amir
I'm trying to rollout CiscoTSP driver (from CUCM 11.5 SU3b) using Command Line. It basically works, but the AUTOUPGRADE_TYPE option does not work as expected and documented.
For example I use the following cmd string for setup:
CiscoTSPx64.exe /s /v"/qn PASS=\"password\" USER=\"user\" CTI1=\"1.1.1.1\" AUTOUPGRADE_TYPE=\"NEVER\" CTI1_TYPE=\"ipv4\""
But after installation I could see that the Option “AUTOUPGRADE_TYPE=NEVER” was ignored and AUTOUPGRADE is still active.
Do you have any suggestion?
Thank you for your help.
rajangra
Hi Ali,
You should use AUTO_TYPE=\"NEVER\" in place of AUTOUPGRADE_TYPE=\"NEVER\”.
This is known a issue where we need to modify the related document.
