Capturing Call Answer event
ashish.nijai
Level 2
Level 2
I am having difficulties in getting call answered event.
Call Answered means when called party answers phone
I am monitoring a CUCM extension.
Initially I used CiscoRTPOutputStartedEv event to signal answered event.
It worked well with extensions which are in local CUCM.
When i called to local extensions, CiscoRTPOutputStartedEv got caught when call answered by called party.
When I called to PSTN using CUCM extension, CiscoRTPOutputStartedEv event got captured when call was in ringing state.
When called party answerd call, CiscoRTPOutputStartedEv not captured by JTAPI.
I used events like CallCtlTermConnTalkingEv,CallCtlConnEstablishedEv but unable to get any solution.
Am I using right approach to capture Call Answered event?
Is there another way to capture call answered event?
Please guide me about same
upchaurasia
Hi Ashish,
Use CallCtlConnEstablishedEv event and check if both terminal connection are in "TALKIN" states. App will receive 2 CallCtlConnEstablishedEv event.
Umesh
upchaurasia
Hi Ashish,
Umesh
Hello Umesh,
Can you please elaborate how to apply this as i am new with Jtapi and i am facing the same issue with (PSTN) phones i apply this condition to check if the state is answered or not but it works only with Ip phones
if (( mycall.getConnections()[1].getState() == Connection.CONNECTED)
                   &&(mycall.getConnections()[0].getState() == Connection.CONNECTED)
can you tell me how to apply your solution.
Mohamed
