CISCO IP Telephony (Using ATAPI)
dtsdebajyoti
I need to create an app which will allow Supervisors to Monitor/Coach Agents on CISCO IP phone from server. The app will be in C#. I have tried using ATAPI wrapper, but it can't detect active call in the server. Please let me know what configuration or code is needed for me. Please provide sample code which will satisfy my requirements. Attached is the sample code used by me.
Also please provide sample project in JAVA using JTAPI for the same.
to get the terminalConnections from an ongoing call, application needs to add a callObserver on the address/terminal.
  CiscoTerminal ciscoTerminal2 = (CiscoTerminal) ciscoAddress2.getTerminals()[0];
  //missing from code
ciscoTerminal2.addCallObserver( <instance of a callObserver>);
  TerminalConnection terminalConnection = ciscoTerminal2.getTerminalConnections()[0];
  if (terminalConnection.getState() == TerminalConnection.ACTIVE)
amoherek
Yes I have gone through these links, but didn't find the solution I want. Can anyone modify my sample code for monitor and coach functionality?
Now I am using JTAPI to start a whisper call to the agent 201 from supervison 101. Agent (201) is engaged with 101. I am using the following jave code:
String providerString = "10.225.110.20;login=jtapi_login;passwd=cisco_pwd";
            CiscoJtapiPeer ciscoJtapiPeer = (CiscoJtapiPeer) JtapiPeerFactory.getJtapiPeer(null);
            CiscoProvider ciscoProvider = (CiscoProvider) ciscoJtapiPeer.getProvider(providerString);
            ciscoProvider.addObserver(this);
            CiscoAddress ciscoAddress = (CiscoAddress) ciscoProvider.getAddress(ExtFromCoach);
            CiscoTerminal ciscoTerminal = (CiscoTerminal) ciscoAddress.getTerminals()[0];
            CiscoAddress ciscoAddress2 = (CiscoAddress) ciscoProvider.getAddress(ExtToCoach);
                CiscoCall ciscoCall = (CiscoCall) ((CiscoProvider) ciscoAddress.getProvider()).createCall();
                Connection[] conntections = ciscoCall.startMonitor
                                                    ciscoTerminal,
                                                    ciscoAddress,
                                                    terminalConnection,
                                                    CiscoCall.WHISPER_MONITOR,
                                                    CiscoCall.PLAYTONE_NOLOCAL_OR_REMOTE
I am not getting any active connections and also no monitoring starts. Please let me know where is the problem with my code.
  //missing from code
